Forum des Kerkenniens Index du Forum
Forum des Kerkenniens Index du ForumFAQRechercherS’enregistrerConnexion
Partager
:: Cheap Tampa Bay Buccaneers Shirts ::
Poster un nouveau sujet   Répondre au sujet    Forum des Kerkenniens Index du Forum -> Forum des Kerkenniens -> Remarques et Critiques
bears123
Point(s): 305
MessagePosté le: Sam 11 Aoû - 01:57 (2018)    Sujet du message: Cheap Tampa Bay Buccaneers Shirts Répondre en citant
From matte to a high gloss finish Wholesale Tampa Bay Buccaneers Shirts , there are different levels of sheen and aggregate exposed on polished concrete floors. These amount of aggregate and level of sheen on polished concrete floors depend on the diamond grit used to polish the concrete floor. According to the Concrete Polishing Association of America, the gloss levels of polished concrete in Kansas City is classified broadly as A, B, C, and D depending on the diamond grit used. Here is a brief review of the different levels of sheen and aggregate exposure on polished concrete floors.
Level 1
This level 1 also referred to as 'flat' ground polish will look slightly hazy when looking directly down at the floor. By halting below the 100 grit resin bond, this look can be achieved and will have very little if any reflection or clarity.
Level 2
By halting at the 400 grit resin bond, this level two polishes has a honed appearance and results in a low gloss finish. When you look directly down at such types of flooring, the floor will expose a very slight reflection which can also be seen from a distance of about 100 feet. Also called as 'Satin', this finish results in a low luster matte appearance.
Level 3
When compared to level 1 and level 2 polishes Wholesale Tampa Bay Buccaneers Jerseys , the level three semi-polished surface has got a lot more shine. This gloss finish is obtained by using an 800 grit or greater diamond abrasive. With this sheen level, you will begin to see a decent reflection of light on the surface. The floor will reflect overhead and side lighting clearly, even if you view 30 to 50 feet from the floor.
Level 4
Level 4 finish provides a high level of polish and hence called as 'highly-polished' level. When looking directly down the polished surface, you can see your own reflection with total clarity. Moreover, the floor may also appear to be wet while looking from different angles. To achieve this level of sheen, a 3,000 grit resin bond diamond and a high-speed burnisher with specifically outfitted buffing pads are typically used.
Levels of Aggregate Exposure
With a low level of exposure, class A aggregate exposures appear as a cream color whereas class D has a large aggregate exposure of up to ¼ of an inch. But remember, due to the very small amount being cut from the surface Wholesale Buccaneers Hats , these cream blemished does not remove surface blemishes or existing imperfection in the concrete. Also, while class D aggregate exposure is visually appealing, it's harder to achieve and increase costs due to possible pits or divots being exposed.
To know more about concrete polishing in Kansas City, visit https:kansascityconcretesolutions The healthcare technology space is constantly impacted by regulatory change (e.g., Meaningful Use, HIE, ACO, HIPAA and P4P requirements), evolving healthcare standards (e.g. Wholesale Buccaneers Hoodies , HL7, ICD-10, XDSXDSi), and innovations in technology (e.g. HTML5, MVC 4.0, healthcare mobile app development, cloud computing, etc). Healthcare organizations are under constant pressure to improve quality of care while also reducing costs.
Given the complex IT systems in hospitals and other provider settings, this is easier said than done.The healthcare IT ecosystem often involves hundreds of speciality areas Wholesale Buccaneers Shirts , thousands of disparate systems, and varying types of healthcare data structures and formats.New application vendors need to invest significant effort and cost in integrating their applications with other applications in a hospital –healthcare application development (EMR, PHR, lab, point-of-care systems), medical imaging (RIS, PACS), financial (RCM, claims Wholesale Buccaneers Jerseys , collections, denials) and other departmental applications. They need to worry about how they can connect and share information with HIEs, ACOs and other healthcare organizations, (including clinicians, primary care physicians, labs, acute care facilities, physician practices, hospitals Cheap Tampa Bay Buccaneers Hats , PCMHs). This means creating multiple standards based connections with a large variety of external systems, such as EHRs, lab systems, PHR systems, drug data, RISPACS, RCM, HIE platforms. They would then need to support this entire complex set of applications and connections effectively across thousands of such installations across the healthcare ecosystem.
The key to addressing this level of complexity often lies in getting the right technology partner on board! While most technology solution providers claim to have some capabilities in healthcare applications, companies should be careful in their choice of partner. Some key questions that need to be asked are:
• What is the technology partner’s knowledge of healthcare workflows – does the solution provider have extensive exposure to real deployments and use cases around emerging trends like healthcare mobile app development Cheap Tampa Bay Buccaneers Hoodies , cloud computing and big data analytics?
• Does the partner have strong healthcare application development expertise across a wide range of clinical, imaging, financial and operational applications, since most solutions would involve dealing with multiple types of applications?
• With interoperability and integration (both internal and external) being a critical component, does the partner have a deep understanding of healthcare interoperability standards (HL7, DICOM, XDS, SNOMED, and LOINC)? Also Cheap Tampa Bay Buccaneers Shirts , does the partner have real experience with integration technologies and platforms (e.g., Cloverleaf, Ensemble, Rhapsody, etc.)?
• Considering the strong data privacy needs with respect to healthcare information, mandatedby HIPAA, does the partner really understand what it takes to ensure data security and privacy, including protection of Personal Health Information (PHI) across distributed networks?
A key success factor in successful healthcare appli. Wholesale Jerseys From China   Wholesale Jerseys China Online   Cheap Jerseys China   Wholesale Football Jerseys Online   Wholesale NCAA Jerseys From China   Cheap Basketball Jerseys   Cheap Baseball Jerseys   Cheap Soccer Jerseys China   Cheap NHL Hockey Jerseys   Cheap NFL Jerseys China
MessagePosté le: Sam 11 Aoû - 01:57 (2018)    Sujet du message: Publicité
Poster un nouveau sujet   Répondre au sujet    Forum des Kerkenniens Index du Forum -> Forum des Kerkenniens -> Remarques et Critiques Toutes les heures sont au format GMT + 1 Heure
Partager
Index | créer un forum gratuit | Forum gratuit d’entraide | Annuaire des forums gratuits | Signaler une violation | Conditions générales d'utilisation
Powered by MA-Design
